Hi, I do not think the default calendar has such a configuration, you will need to either build a custom calendar plugin, or perhaps use some custom JavaScript.
Hey,
I want a calendar from which I can select a number of date ones I select the dates. The dates should get displayed/listed below. How can I achieve it?
