      If its a CRUD menu, go to "Userview Builder > CRUD menu > Properties > UI (Edit) or UI (Add)".
      Read at CRUD Menu#Add.
      1. aimi
        i'm don't have CRUD.
      You can use Javascript/jQuery code to relabel buttons, set in "Userview Builder > Advance > Custom JavaScript":
      $(function(){
      	$("#cancel").val("Close");
      I google and found lots of JS examples in Joget's Javascript API.
