I have Datalist with JDBC Datalist Database Binder. I configure the filter with "Date Range" type. But the Date Range Filter does not appear in userview as shown below.
Thus i cannot filter based date range.
After configure with "Date Range" filter, i cannot edit the range element. I should remove the datalist and create from the beginning.
I use this property
* Data Format : yyyy-MM-dd
* Display Format : yy-M-dd
      Dear Andrew,
      I found the problem. I select "JDBC Datalist Database Binder" in "Select Source of Data (Binder)" with manual sql query.
      When change the source to "Advanced Form Data Binder", the problem is solved. The Date Range Picker in Filter Area is appear and Date Range Filter can be edited.
      Thanks for your respon.
        Attached is a demonstration app for datalist with date range and the data source is using JDBC binder.
        Do try out the app. You can view the datalist properties in this app for comparison/learning.
        APP_29821835-Datalist-Date-Range.jwa
