I'm using Joget DX Enterprise 7
I want to put the New Button in the Top Left & Bottom Left and I want to put the Delete button in the screen
There's a document in how to do it:
https://dev.joget.org/community/display/DX7/CRUD+Menu
The document talks about Crud Properties (Button Position (cool) and delete Button) , but does not show how to get in the Edit Crud Properties Screen
So, I couldn't make what I need.
( I've searched a lot in joget foruns, docs, and youtube channel)
      Hi, I am not certain I understand the question correctly. If the question is " how to get in the Edit Crud Properties Screen", then in the Userview Builder you hover your cursor over the CRUD element in your userview, click on the pencil Properties icon button. In the property editor, click on Next to show CRUD Menu#List and the "Show Delete Button" option is available there.
      1. Evandro
        Thank you Anders !!
        You solved my question
        (The steps you write aren't in any of the Joget Documentation Manual's)
        Thank you again.
      I don't think there's a way to place the button elsewhere unless you use JQuery to do it.
      In CRUD Menu#List, there's a show delete button.
      1. Evandro
        Thank you, Ian.
