    I Googled and found this Joget Plugin Comparison chart for Community/Enterprise features which might help you at https://www.joget.org/product/plugin-comparison/
      Edit: opps, it appears that the options filter is not available in Joget Community version
      You need to drag a filter to the filter panel as highlighted in the image below.
      After dragging the filters you want, hover your mouse over to any filters then click edit as shown in the image below.
      You should now be able to see the options filters
      Hope it helps!
      1. Jagadeeshkumar Viswanathan
        Is it possible to develop the Plugin manually.
      2. Eugene Lee Choon Meng
        Yes, it is possible. You can refer to this link Datalist Filter Type Plugin which might help you.
