Requirement:
I am getting sender, reciever, subject, content, attachment of an Email from  code in email pol my requirement is to post all the data to data list
so please give me proper code to insert all the data in joget datalist
      My data was from Outlook I have completed my task by JDBC binder
        Hi, it depends on which binder you are using for your datalist. If you are reading from a database, then you can insert the data directly into your database using JDBC like in Store Form Field Data to Multiple Tables. If your data is from an API then you would insert the data into that service, and so on.
