I'm developing a vendor evaluation system where vendors need to edit the evaluation form when extending their contract to include the extended contract date. This requires going through the evaluation process again. What should i do?
      Add a route. Use it to check if you want to start the process again.
      Your transition should be go back to the activity from where you want the user to start again
