Hi Folks, i have a Select Box and need filter the information regarding the previous selection of a Popup select box  in the same form.
The questions are:
  1. Can i filter the options in the Select Box (that use Default Form Option Binder) regarding a value of Popup Select Box (that use a datalist ) in the same form?
    Or
  2. if  i use the  Extra Filter Condition feature ?
    Could i  use a HQL  with a HASH variable that get the value of a Popup Select Box in the same form?
This is the scenary:
I have to choice a customer in the Popup Select Box first and later and need choice a customer contact in the second Select Box (of course both have relations from  two  tables)
It is the Popup Select Box
If i use this sentence the Contact is filter as in need.
e.customProperties.account = 'QC0003'
but need that it work dinamically
      Hi, if you need it to be dynamic within the same form then you cannot use binders or hash variables as those require server-side processing. You need to use something client-side AJAX related, for example Ajax Cascading Drop-Down ListDynamic Cascading Drop-Down List or AJAX Subform.
