This code Setting Workflow Variable Value in Process Tool Bean Shell doesn't work since the start activity has no activity ID.
So, is there a way to set the workflow variable value right after the start activity?
      Hey there Sarah,
      You can have a look at this plugin from the Joget Marketplace:
      https://marketplace.joget.org/jw/web/userview/mp/mpp/_/vad?id=WVariable_Update_Tool-1
      Just append a process tool after the start node and before your first activity, and use this plugin.
      Hope this helps!
