Joget DX Beta Available for Download
I get the following error when deploying a very simple process. Can any one help on that?
ERROR 10 Jan 2019 12:54:54 Shark - PackageAdmin -> Package byte[] representation failed to open
ERROR 10 Jan 2019 12:54:54 org.joget.workflow.model.service.WorkflowManagerImpl - org.enhydra.shark.api.internal.repositorypersistence.RepositoryException: DODSRepositoryPersistenceManager -> The upload of xpdl OA_001 failed
com.lutris.appserver.server.sql.ObjectIdAllocationError: ObjectIdAllocator:
Failed to allocate object id. Caused by SQLException:
SQLState = 23000
SQLError = 1062
SQLMsg = (conn:1600) Duplicate entry '1000400' for key 'PRIMARY'
at com.lutris.appserver.server.sql.standard.StandardObjectIdAllocator.updateCache(StandardObjectIdAllocator.java:447)
at com.lutris.appserver.server.sql.standard.StandardObjectIdAllocator.allocate(StandardObjectIdAllocator.java:239)
at com.lutris.appserver.server.sql.standard.StandardLogicalDatabase.allocateObjectId(StandardLogicalDatabase.java:602)
at com.lutris.dods.builder.generator.dataobject.GenericDO.allocateFakeOId(GenericDO.java:223)
at com.lutris.dods.builder.generator.dataobject.GenericDO.<init>(GenericDO.java:255)
at org.enhydra.shark.repositorypersistence.data.NextXPDLVersionDO.<init>(NextXPDLVersionDO.java:445)
at org.enhydra.shark.repositorypersistence.data.NextXPDLVersionDO.createVirgin(NextXPDLVersionDO.java:1441)
at org.enhydra.shark.repositorypersistence.DODSRepositoryPersistenceManager.updateNextVersion(DODSRepositoryPersistenceManager.java:262)
at org.enhydra.shark.repositorypersistence.DODSRepositoryPersistenceManager.uploadXPDL(DODSRepositoryPersistenceManager.java:96)
at org.enhydra.shark.PackageAdmin.copyPackagesToInternalPackagesRepository(PackageAdmin.java:1019)
at org.enhydra.shark.PackageAdmin.openPackage(PackageAdmin.java:908)
at org.enhydra.shark.PackageAdmin.uploadPackage(PackageAdmin.java:238)
at org.joget.workflow.model.service.WorkflowManagerImpl.processUpload(WorkflowManagerImpl.java:943)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at org.springframework.transaction.interceptor.TransactionAspectSupport.invokeWithinTransaction(TransactionAspectSupport.java:281)
at org.joget.apps.app.service.AuditTrailInterceptor.invoke(AuditTrailInterceptor.java:17)
at org.joget.apps.app.service.SqlFilterAspect.invoke(SqlFilterAspect.java:36)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:213)
at com.sun.proxy.$Proxy27.processUpload(Unknown Source)
at org.joget.apps.app.service.AppServiceImpl.deployWorkflowPackage_aroundBody12(AppServiceImpl.java:1176)
at org.joget.apps.app.service.AppServiceImpl$AjcClosure13.run(AppServiceImpl.java:1)
at org.springframework.transaction.aspectj.AbstractTransactionAspect.ajc$around$org_springframework_transaction_aspectj_AbstractTransactionAspect$1$2a73e96cproceed(AbstractTransactionAspect.aj:66)
at org.springframework.transaction.aspectj.AbstractTransactionAspect$AbstractTransactionAspect$1.proceedWithInvocation(AbstractTransactionAspect.aj:72)
at org.springframework.transaction.aspectj.AbstractTransactionAspect.ajc$around$org_springframework_transaction_aspectj_AbstractTransactionAspect$1$2a73e96c(AbstractTransactionAspect.aj:70)
at org.joget.apps.app.service.AppServiceImpl.deployWorkflowPackage(AppServiceImpl.java:1148)
at com.sun.proxy.$Proxy57.deployWorkflowPackage(Unknown Source)
at org.joget.apps.app.controller.ConsoleWebController.consolePackageUploadSubmit(ConsoleWebController.java:1677)
at org.joget.apps.app.controller.ConsoleWebController$$FastClassBySpringCGLIB$$e1402d89.invoke(<generated>)
at org.springframework.cglib.proxy.MethodProxy.invoke(MethodProxy.java:204)
at org.springframework.aop.framework.CglibAopProxy$DynamicAdvisedInterceptor.intercept(CglibAopProxy.java:651)
at org.joget.apps.app.controller.ConsoleWebController$$EnhancerBySpringCGLIB$$ef05d3b1.consolePackageUploadSubmit(<generated>)
at org.springframework.web.bind.annotation.support.HandlerMethodInvoker.invokeHandlerMethod(HandlerMethodInvoker.java:180)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:963)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:897)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
at org.joget.apps.app.web.ExpireFilter.doFilter(ExpireFilter.java:44)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:595)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:140)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:342)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:803)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:868)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1459)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
at org.enhydra.shark.repositorypersistence.DODSRepositoryPersistenceManager.uploadXPDL(DODSRepositoryPersistenceManager.java:110)
Caused by: com.lutris.appserver.server.sql.ObjectIdAllocationError: ObjectIdAllocator:
SQLState = 23000
SQLError = 1062
... 134 more
  1. abdul Fattah
    can you put your process flow first?
  2. zhenlei ge
    Nothing related to the process flow. It was solved by reinstalling Joget and the database. Thank you anyway.
    Hi, the error Duplicate entry '1000400' for key 'PRIMARY' seems to indicate that the database might have corrupted data.
    1. zhenlei ge
      I think so. But that log did not help on identifing the problem. It didn't tell me which table, which operation caused the error. Anyway, it was solved.
