Are you building a plugin or using customHTML form element? In https://dev.joget.org/community/display/KBv6/Hash+Variable#HashVariable-FormDataHashVariable it clearly mentioned that the scope of use for this hash variable is
Am using in my custom web service plugin
Hi, there is not enough information, what specific hash variable and page numbers do you mean? Any errors in the console or logs?
Attached sample Document. I used hash variables in customHtml field
Am creating web service plugin to generate PDF using formId and primary key,
It's not rendering hash variable and the page number is not showing.
Please help!
