Hi,you could use Subflows (Subprocesses). Alternatively you could also have separate processes that are triggered using Sample JSON API Integration#StartaProcess. Or you could also have it manually started by a user in Start Process from Datalist Hyperlink Action. There are many ways to do it depending on what you really need.
Hey Anders, thank you for your answer and explanation I will be looking more into it.
Hello everyone, I am new in Joget as well as in BPM. I would like to ask from the experts about Sequential Process. All I understand is it like a chain of processes that need the previous process to be done before continuing to the next process. With this understanding, I was trying to implement it in Joget. However, I could not understand how we can connect each of the process. Is it by using sub-process? Thanks before![(smile)](/community/s/8kxef7/9012/cuccqr/_/images/icons/emoticons/smile.svg)
