You can try the attached sample app below to view the Option Binder Hash Variable in action.
Login as admin, import, publish and run the app and go to "Manage Form" menu, add a record and reopen the same record to view the hash variable examples (in Custom HTML form).
How to use binder hash variable in the form to get a select box label?
eg:
#binder.options.sps_qcp.qcp_request_fm.product_type#
Used this in form field by setting as a default value, custom HTML. But not rendering anything.
Not clear in the website.
