Hi, all, brand new to Joget so please forgive me if this is obvious.
I am working on an app and I want to set a couple a parameters that "follow" an end user around and filter data based on these parameters. I see that I can use hash variables to requestparam or userviewkey in my filters so that would be perfect.
Is it possible to have a form or something similar where the user can select the parameters (can be changed at will).
Thanks!
      Hi, as described in the Userview Key page, the userview key is located in the URL. So if you need to, you could have a form or link that sets the appropriate value in the URL.
      1. Nate Bergeron
        Thanks for the reply! You listed the exact point at which I'm stuck and hoping to get some suggestions. How do I use a form to set the appropriate value in the URL (either userviewkey or requestparam)
