I am and other are getting the below message when using the system.
I am the administrator and get it regularly. Can anyone assist?
      Hello, in my case that has happened to us when there is any change in the administration of the database server. Did you change your password, user, or permissions? Or the database server stopped being online?
      Do you have the possibility to check the application log?
        No, change of that nature has occured. Where can I go to view those logs?
        1. Camilo A. García
          Depending on your installation:
          /Joget-v6-Professional/apache-tomcat-X.X.XX/logs/catalina.out
