I am using bean shell to read the email from outlook I am getting the data in this format
I am using this code to read the multipart emails
public String getTextFromMessage(Message message) throws MessagingException, IOException {
    String result = "";
    if (message.isMimeType("text/plain")) {
        result = message.getContent().toString();
    } else if (message.isMimeType("multipart/*")) {
        MimeMultipart mimeMultipart = (MimeMultipart) message.getContent();
        result = getTextFromMimeMultipart(mimeMultipart);
    return result;
public String getTextFromMimeMultipart(
        MimeMultipart mimeMultipart)  throws MessagingException, IOException{
    String result = "";
    int count = mimeMultipart.getCount();
    for (int i = 0; i < count; i++) {
        BodyPart bodyPart = mimeMultipart.getBodyPart(i);
        if (bodyPart.isMimeType("text/plain")) {
            result = result + "\n" + bodyPart.getContent();
            break; // without break same text appears twice in my tests
        } else if (bodyPart.isMimeType("text/html")) {
            String html = (String) bodyPart.getContent();
            result = result + "\n" + org.jsoup.Jsoup.parse(html).text();
        } else if (bodyPart.getContent() instanceof MimeMultipart){
            result = result + getTextFromMimeMultipart((MimeMultipart)bodyPart.getContent());
    return result;
How can I get this data in this format
      Hi, from the code it appears you are specifically retrieving text from the emails, and the screenshot does show extracted text. What is wrong and what is expected?
