Hi ,
I want conditional delete in joget datalist. Like if i have form 1 which is submitted and for this form 1 any specific action is taken via form 2 , then while deleting it , message should appear that this form is link to Form 2. You can not delete it. Same for edit.
      Hi, I believe you can use a custom Datalist Action to implement custom behavior like this. Either build a custom plugin, or make use of the Bean Shell Action.
