How to make form grid element mandatory . If i submit the form without filling grid table it should throw error.
I tried Grid Filed Basic Validator but not working.
      There is a "Validation & Data binder" tab on form grid defeinition. In this tab there is a "Min Number of Row Validation (Integer)" where you can specify the minimum rows in the grid. Underneeth that parameter you can find an Error message field, which used to populate error message if the row requirements set above is not met.
        Thank You Mate.
