I want to redirect to particular URL using Bean Shell Datalist Action.
My Bean Shell Code is:
import java.sql.Connection;
import java.sql.ResultSet;
import java.sql.SQLException;
import javax.sql.DataSource;
import java.lang.String;
import java.util.Date;
import java.text.DateFormat;
import java.text.SimpleDateFormat;
import java.util.Calendar;
import org.joget.apps.datalist.model.DataListActionResult;
    Connection con = null;
    try {
        // retrieve connection from the default datasource
        con = ds.getConnection();
        con.setAutoCommit(false);
        if (!con.isClosed()) {
            DataListActionResult result = new DataListActionResult();
            result.setType(DataListActionResult.TYPE_REDIRECT);
            int count = rowKeys.length;
	        // Here Multiple Database Operations
            con.commit();
            con.close();
            result.setUrl("https://www.google.com/");
            return result;
    catch (Exception e) {
        con.rollback();
    finally {
        if (con != null) {
            con.close();
Here, DB operations working perfectly but there is a issue to redirect to URL.
Can anyone tell me Is this is perfect for redirection or I can use another option for redirection.
Thanks!
      I tried your simplified code to validate if redirection works or not.
      return result;
      redirection happens correctly. there might be something wrong with the logic in your overall code then.
