Is there an example where values retrieved from a Bean shell are injected into a custom HTML Table.
Is there a sample application where we can see the values retrieved from the backend database using custom Bean are displayed in a pop-up.
      See sample code at Bean Shell Programming Guide#UseasFormLoadBinderFormLoadBinder
      In the form section, put in the code to set to i.e. field "X". Declare a textarea/textfied with ID "X".
      You don't need a custom HTML and trying to repeat the front end coding. Use the approach above is easier.
