{{renderer:function(instance, td, row, col, prop, value, cellProperties){Handsontable.renderers.TextRenderer.apply(this, arguments);td.style.backgroundColor = '#D8E4BC';}
renderer:function(instance, td, row, col, prop, value, cellProperties){Handsontable.renderers.TextRenderer.apply(this, arguments);td.style = 'numeric';}
Would like to do two things change color and use numeric with 0.00 using Custom properties .
      This work
      1.Formatting number
      {{type:'numeric',numericFormat:{pattern:'0.000'}}}  (Works Okay)
      2. Formatting Color works
      Handsontable.renderers.TextRenderer.apply(this, arguments);td.style.backgroundColor = '#FDE9D9';
      }}   (Works Okay)
      3. combining the above two does not work.
      type:'numeric',numericFormat:{pattern:'0.00'},
      Handsontable.renderers.TextRenderer.apply(this, arguments) ; td.style.backgroundColor = '#FDE9D9';
      }}  Does not work.
      Example
      type:'date',dateFormat:'MM/DD/YYYY' ,
      }} This works as well.
        Hey Justin It does not work I tested it. did you test it ?
          Hi, perhaps you can try it like this?
                 renderer: function(instance, td, row, col, prop, value, cellProperties) {
