Hi There
I'm using the DX cloud version and am wanting to access a JSON API via ajax from the web browser of a signed in user.
The specific JSON API is the data list API: https://kiwicivil.cloud.joget.com/jw/web/json/data/list/kc1/equipmentList
eg:
$.ajax({
  type: "POST",
  url: 'https://kiwicivil.cloud.joget.com/jw/web/json/data/list/kc1/equipmentList',
  success: function(res) {
    console.log(res);
  dataType: "jsonp",
  cache: false
If I am logged in as the administrator, then this work fine.
However if I am logged in as another user, then I get a 403 response.
If I include a data element,  eg:
data: {
  j_username : 'admin',
  j_password : 'xxxx',
  loginAs : 'xxxxx'
Then joget changes the login for the entire browser session.
Is there any way that I can access the JSON API as an existing signed in user without it returning a 403 error?
Cheers
Dave
      Hi Anders
      Thanks for this, I missed the significance of that in the documentation. That would explain why the JSON call only worked when logged in as admin.
        Hi, according to the docs JSON API#web/json/data/list/(*:appId)/(*:listId) that API is for the admin role. If you need something different, you can use the API Builder to build your custom APIs.
