Hello,
I have a form in which using the Download PDF Datalist Action I am creating a PDF of the form. I want to put a page break in that PDF. Is there a way to customize the PDF with the page-break?
Thanks in advance,
Sebnem
      It uses html to pdf conversion. You can google for the correct css / HTML coding to achieve that. Joget uses ITextRenderer.
      See https://github.com/jogetworkflow/jw-community/blob/7.0-SNAPSHOT/wflow-core/src/main/java/org/joget/apps/form/service/FormPdfUtil.java#L118
      Try
      <div style="page-break-before: always; page-break-after: always; width: 100%; height: 500px; background-color: gainsboro; border: 2px solid gray; text-align: center">
      inside your form → custom HTML to introduce the page break.
      Reference: https://www.evopdf.com/demo/HTML_to_PDF/Page_Breaks/Insert_Page_Breaks_Before_After_Using_CSS.aspx
      1. Sebnem Kabadayi
        Thank you! It worked. I've used simply this line in the custom HTML :
        <div style="page-break-before : always"></div>
