First of all, i'm doing my 1srt steps with Joget and if this seems a trivial question for you, i apologize.
I need to have a field in my form that shows the cost center in each department, like this structure:
Department (eg: Operations)
    - Cost Center (eg: RH) (should appear a list with cost centers of that department)
          - Budget Line (eg: John Doe) (should appear a list with users of that cost center)
How can i create this structure and insert it into a form?
I'm using a cloud version.
Thank you in advance
      Can u try using Ajax Subform Form? AJAX Sub Form gives you the flexibility of dynamically loading a Subform by attaching a listener to other form field. Form more information about AJAX Subform.
      Thank you.
