I definitely want offline access as we use it for inspections on tablets in the field.
I understand the lookups of data wont work but I cant seem to get a grid form working when it pops up a subform it keeps saying not available offline.
Hi, if you do not need offline functionality then you can ignore that warning. If you do need offline, I believe elements that require dynamic loading of data from the server would not be supported if you are offline. The form will still work, just that when offline, the data will not load correctly.
Is there any documentation of what elements dont work with PWA? I have a Grid Form that loads a subform which doesn't work. Are there others I should know about? Is there a way to make these work or do I need to remove them completely from the form.
