hi, suddenly i'm encounter this error after restart joget server.
No database configuration was detected, so please configure your database settings below.
upon checking database and table still there. take backups dan restart back both mysql and joget. still joget didnt find corrent db. the setting properties still in wflow folder.
please advice or do we need to call support ?
      Hi, from the description it seems to be missing or corrupted datasource properties files. Try to check for errors in the logs based on  Troubleshooting - Common Errors. The error messages should help pinpoint the problem.
        found that misconfigured startup bat file causing this problem. luckily we do not proceed with db setup.  thanks @Anders
