With the following script, I am able to get the requestor name but I am unable to get for the department. I though just changing the hash variable "#currentUser.username#" to  "#user.username.department.name#" will get me the department.
import java.sql.*;
import org.apache.commons.collections.SequencedHashMap;
import java.util.*;
public FormRowSet test() {
FormRowSet f = new FormRowSet();
f.setMultiRow(true);
FormRow r1 = new FormRow();
r1.put("requestorUserName", "#currentUser.username#");
f.add(r1);
return f;
return test();
      If you want the current user's data, use Hash Variable#CurrentUserHashVariable
      If you want other users, use Hash Variable#UserHashVariable
      Have you tried #currentUser.department.name#?
      1. Aaron Tan
        Good day,
        Yes, I have tried the hash, #currentUser.department.name# before posting. I will get the info as shown below
      2. Ian
        Ah i see, #currentUser.department.name# is only available for enterprise edition. Since you're using community edition, you'll probably need to perform a SQL query to get the department name.
        Something like :
        SELECT name FROM dir_department d INNER JOIN dir_employment e ON d.organizationId = e.organizationId WHERE e.userId = #currentUser.username#
      3. Aaron Tan
        Oh no wonder, I though the enterprise edition only apply for the below attribute. Anyway, thank you for taking your time to clarified on this matter.
