I currently hosting a Support request form which is starting point of a process (using link option) at 3th part Site.
May I ask you guys is their a way to customize the CSS of that form ?
Thank you,
      Hi, you can place custom CSS in a Custom HTML element in your form, or in the properties of the userview menu you are using, depending on which one you are using.
