You can use the "Form Builder > Spreadsheet > Properties > Row > Regex Validation" property field to define your input rules. See https://www.sitepoint.com/learn-regex/ .
Hi everyone,
I want to put condition or restriction in my spreadsheet.
First column, user can insert maximum 10 digits. Less is acceptable.
Second column, user must insert 14 digits and 1 alphabet. Cannot less or more.
If either one is incorrect system will show error. Thank you!
