T E S T S
Running org.joget.commons.util.TestStringUtil
log4j:WARN No appenders could be found for logger (org.springframework.test.context.junit4.SpringJUnit4ClassRunner).
log4j:WARN Please initialize the log4j system properly.
log4j:WARN See http://logging.apache.org/log4j/1.2/faq.html#noconfig for more info.
Tests run: 12, Failures: 0, Errors: 12, Skipped: 0, Time elapsed: 8.345 sec <<< FAILURE!
testEscapeJS(org.joget.commons.util.TestStringUtil) Time elapsed: 0.004 sec <<< ERROR!
java.lang.IllegalStateException: Failed to load ApplicationContext
at org.springframework.test.context.cache.DefaultCacheAwareContextLoaderDelegate.loadContext(DefaultCacheAwareContextLoaderDelegate.java:124)
at org.springframework.test.context.support.DefaultTestContext.getApplicationContext(DefaultTestContext.java:83)
at org.springframework.test.context.support.DependencyInjectionTestExecutionListener.injectDependencies(DependencyInjectionTestExecutionListener.java:117)
at org.springframework.test.context.support.DependencyInjectionTestExecutionListener.prepareTestInstance(DependencyInjectionTestExecutionListener.java:83)
at org.springframework.test.context.TestContextManager.prepareTestInstance(TestContextManager.java:230)
at org.springframework.test.context.junit4.SpringJUnit4ClassRunner.createTest(SpringJUnit4ClassRunner.java:228)
at org.springframework.test.context.junit4.SpringJUnit4ClassRunner$1.runReflectiveCall(SpringJUnit4ClassRunner.java:287)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:12)
at org.springframework.test.context.junit4.SpringJUnit4ClassRunner.methodBlock(SpringJUnit4ClassRunner.java:289)
at org.springframework.test.context.junit4.SpringJUnit4ClassRunner.runChild(SpringJUnit4ClassRunner.java:247)
at org.springframework.test.context.junit4.SpringJUnit4ClassRunner.runChild(SpringJUnit4ClassRunner.java:94)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:290)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:71)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:288)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:58)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:268)
at org.springframework.test.context.junit4.statements.RunBeforeTestClassCallbacks.evaluate(RunBeforeTestClassCallbacks.java:61)
at org.springframework.test.context.junit4.statements.RunAfterTestClassCallbacks.evaluate(RunAfterTestClassCallbacks.java:70)
at org.junit.runners.ParentRunner.run(ParentRunner.java:363)
at org.springframework.test.context.junit4.SpringJUnit4ClassRunner.run(SpringJUnit4ClassRunner.java:191)
at org.apache.maven.surefire.junit4.JUnit4Provider.execute(JUnit4Provider.java:252)
at org.apache.maven.surefire.junit4.JUnit4Provider.executeTestSet(JUnit4Provider.java:141)
at org.apache.maven.surefire.junit4.JUnit4Provider.invoke(JUnit4Provider.java:112)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at org.apache.maven.surefire.util.ReflectionUtils.invokeMethodWithArray(ReflectionUtils.java:189)
at org.apache.maven.surefire.booter.ProviderFactory$ProviderProxy.invoke(ProviderFactory.java:165)
at org.apache.maven.surefire.booter.ProviderFactory.invokeProvider(ProviderFactory.java:85)
at org.apache.maven.surefire.booter.ForkedBooter.runSuitesInProcess(ForkedBooter.java:115)
at org.apache.maven.surefire.booter.ForkedBooter.main(ForkedBooter.java:75)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'setupSessionFactory' defined in class path resource [commonsApplicationContext.xml]: Invocation of init method failed; nested exception is org.hibernate.HibernateException: Access to DialectResolutionInfo cannot be null when 'hibernate.dialect' not set
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1631)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:553)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:481)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:312)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:230)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:308)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:197)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:742)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:867)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:543)
at org.springframework.test.context.support.AbstractGenericContextLoader.loadContext(AbstractGenericContextLoader.java:128)
at org.springframework.test.context.support.AbstractGenericContextLoader.loadContext(AbstractGenericContextLoader.java:60)
at org.springframework.test.context.support.AbstractDelegatingSmartContextLoader.delegateLoading(AbstractDelegatingSmartContextLoader.java:281)
at org.springframework.test.context.support.AbstractDelegatingSmartContextLoader.loadContext(AbstractDelegatingSmartContextLoader.java:249)
at org.springframework.test.context.cache.DefaultCacheAwareContextLoaderDelegate.loadContextInternal(DefaultCacheAwareContextLoaderDelegate.java:98)
at org.springframework.test.context.cache.DefaultCacheAwareContextLoaderDelegate.loadContext(DefaultCacheAwareContextLoaderDelegate.java:116)
... 31 more
Caused by: org.hibernate.HibernateException: Access to DialectResolutionInfo cannot be null when 'hibernate.dialect' not set
at org.hibernate.engine.jdbc.dialect.internal.DialectFactoryImpl.determineDialect(DialectFactoryImpl.java:104)
at org.hibernate.engine.jdbc.dialect.internal.DialectFactoryImpl.buildDialect(DialectFactoryImpl.java:71)
at org.hibernate.engine.jdbc.internal.JdbcServicesImpl.configure(JdbcServicesImpl.java:205)
at org.hibernate.boot.registry.internal.StandardServiceRegistryImpl.configureService(StandardServiceRegistryImpl.java:111)
at org.hibernate.service.internal.AbstractServiceRegistryImpl.initializeService(AbstractServiceRegistryImpl.java:234)
at org.hibernate.service.internal.AbstractServiceRegistryImpl.getService(AbstractServiceRegistryImpl.java:206)
at org.hibernate.cfg.Configuration.buildTypeRegistrations(Configuration.java:1887)
at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1845)
at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1930)
at org.springframework.orm.hibernate4.LocalSessionFactoryBuilder.buildSessionFactory(LocalSessionFactoryBuilder.java:372)
at org.springframework.orm.hibernate4.LocalSessionFactoryBean.buildSessionFactory(LocalSessionFactoryBean.java:454)
at org.springframework.orm.hibernate4.LocalSessionFactoryBean.afterPropertiesSet(LocalSessionFactoryBean.java:439)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1689)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1627)
... 46 more
testEscapeHTML(org.joget.commons.util.TestStringUtil) Time elapsed: 0.002 sec <<< ERROR!
... 31 more
... 46 more
testEscapeJSON(org.joget.commons.util.TestStringUtil) Time elapsed: 0.002 sec <<< ERROR!
... 31 more
... 46 more
testEscapeJava(org.joget.commons.util.TestStringUtil) Time elapsed: 0.005 sec <<< ERROR!
... 31 more
... 46 more
testEscapeNl2Br(org.joget.commons.util.TestStringUtil) Time elapsed: 0.004 sec <<< ERROR!
... 31 more
... 46 more
testEscapeRegex(org.joget.commons.util.TestStringUtil) Time elapsed: 0.002 sec <<< ERROR!
... 31 more
... 46 more
testEscapeExpression(org.joget.commons.util.TestStringUtil) Time elapsed: 0.001 sec <<< ERROR!
... 31 more
... 46 more
testEscapeImg2Base64(org.joget.commons.util.TestStringUtil) Time elapsed: 0.002 sec <<< ERROR!
... 31 more
... 46 more
testEscapeSeparator(org.joget.commons.util.TestStringUtil) Time elapsed: 0.002 sec <<< ERROR!
... 31 more
... 46 more
testEscapeSQL(org.joget.commons.util.TestStringUtil) Time elapsed: 0.002 sec <<< ERROR!
... 31 more
... 46 more
testEscapeURL(org.joget.commons.util.TestStringUtil) Time elapsed: 0.002 sec <<< ERROR!
... 31 more
... 46 more
testEscapeXML(org.joget.commons.util.TestStringUtil) Time elapsed: 0.002 sec <<< ERROR!
... 31 more
... 46 more
Results :
Tests in error:
testEscapeJS(org.joget.commons.util.TestStringUtil): Failed to load ApplicationContext
testEscapeHTML(org.joget.commons.util.TestStringUtil): Failed to load ApplicationContext
testEscapeJSON(org.joget.commons.util.TestStringUtil): Failed to load ApplicationContext
testEscapeJava(org.joget.commons.util.TestStringUtil): Failed to load ApplicationContext
testEscapeNl2Br(org.joget.commons.util.TestStringUtil): Failed to load ApplicationContext
testEscapeRegex(org.joget.commons.util.TestStringUtil): Failed to load ApplicationContext
testEscapeExpression(org.joget.commons.util.TestStringUtil): Failed to load ApplicationContext
testEscapeImg2Base64(org.joget.commons.util.TestStringUtil): Failed to load ApplicationContext
testEscapeSeparator(org.joget.commons.util.TestStringUtil): Failed to load ApplicationContext
testEscapeSQL(org.joget.commons.util.TestStringUtil): Failed to load ApplicationContext
testEscapeURL(org.joget.commons.util.TestStringUtil): Failed to load ApplicationContext
testEscapeXML(org.joget.commons.util.TestStringUtil): Failed to load ApplicationContext
[INFO] Reactor Summary for wflow-app 7.0-SNAPSHOT:
[INFO]
[INFO] wflow-jdbc ......................................... SUCCESS [ 0.641 s]
[INFO] wflow-commons ...................................... FAILURE [ 10.915 s]
[INFO] wflow-plugin-base .................................. SKIPPED
[INFO] wflow-plugin-archetype ............................. SKIPPED
[INFO] wflow-directory .................................... SKIPPED
[INFO] wflow-wfengine ..................................... SKIPPED
[INFO] wflow-core ......................................... SKIPPED
[INFO] wflow-consoleweb ................................... SKIPPED
[INFO] wflow-app .......................................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 11.789 s
[INFO] Finished at: 2020-11-03T17:43:58+08:00
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.4:test (default-test) on project wflow-commons: There are test failures.
[ERROR]
[ERROR] Please refer to D:\joget_src\jw-community\wflow-commons\target\surefire-reports for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException
[ERROR]
[ERROR] After correcting the problems, you can resume the build with the command
[ERROR] mvn <args> -rf :wflow-commons
      Seems to do with passing tests...Have you checked the Build Source Code on Windows? At the bottom of the page, there's a red box mentioning how to pass unit tests
