Hi,,
I switched to the Security Enhanced Manager, probably did not properly configure it. now i cannot login with admin/admin and i dont know how to get access ad admin anymore
Please advise
      Hi, I believe you will need to reset the configuration directly at the database level. In the wf_setup table, try removing the row with the property name "directoryManagerImpl". Do make sure you backup your database before making any changes though just in case.
        Accepted.
