so i used the API Builder to Upload a File and Form Data successfully, I got back a recordId (guid) value, i want to start a process on that recordId ( i know the process information that i want to start, be it ProcessDefinitionID or Name ), the API Builder has a method startProcessByUser and even startProcess, in both cases it wants a "ProcessInstanceId" that ">> has been created but not started << "" that a kicker, how do i do this now. create but not start this needed instance id.
I want to use a REQUEST.POST programmatic call the url to start the process, but with no success here is what i tried
i tried to call the URL  named "Link to Run Process" with an additional &recordId=<uuid-here>, it complains about 403 error
I looked at the beanshell as "Process Tool" idea, but even if i move the call to a new Stub process that collects the RecordId and calls the Main-Target-Process via beanshell, i am still back to square 1, how to i call the Stub Process.
I am considering the Schedule Menu model, but now i got to go look for records without a process instance and try to start a process on that record id
what is it so hard to say POST with a call to say Start Process on a recordId with a user name, Why is there a need to a created but not running instance ?? this is a major hurdle IMHO
Please help ..
      Hi, I believe the query parameters including  processInstanceId are optional parameters. Did you try to make the API call without any additional parameters?
        Yes, it turns out the parameters are optional and it works flawlessly., thanks
