I have one spreadsheet to insert data into database, the primary key {id} is created by SQL. But I want to remove/avoid duplicate data in Spreadsheet. Because the id is different, other column is the same also can be insert successfully. The same record should be removed obviously.
      Thanks for this such an excellent post! Keep up! bad love story
        Hi, if the primary key ID is created automatically, then how would you know whether data is duplicate or not? If you want to avoid such duplicates then I do not think you can use auto-generated IDs.
