I installed Joget DX Enterprise 7.0.11 at C:\JogetDX7-Enterprise then the API Builders plugins, all is well and works.
now i copied C:\JogetDX7-Enterprise\wflow\app_formuploads directory to E:\JogetDX7-Enterprinse\wflow and set the Upload File Storage Base Path in the web UI > Settings and pressed Submit.
Now as soon as i do that and i switched to Forms and UI of an App, i see the Addon Builders menu option is missing. I  edit the "Upload File Storage Base Path" back to blank and press submit, when i switch back to the Forms and UI , its there again.
Seems like Addon Builders is affected by the "Upload File Storage Base Path"
Please advise
      Hi, the storage files consist of all uploaded files which includes plugin files. If you change the storage base path, you would probably need to move/copy everything from your original wflow directory.
