Hi, I am using V6 enterprise. I tried to use the "URL Request Parameters for Datalist" to filter a list grid in a form, it does not seem to work. I used the same method in the popup select box with datalist filtrer which had no problem.
Is this a bug or there is a different way to use it?
Thank you.
      thanks Matthew. however I am talking about a list grid in a form, where there is the Advanced options
      List Grid
      It doesn't seem to work for me.
        Do try the attached app demonstrating the use of hyperlinking to datalist with filter value:
        APP_150307197_parameter_datalist.jwa app.
        When you run the userview app, you will see two menus: List All and List With Filter. The List With Filter menu uses the Link menu element to call the List All menu and passes the filter value in the URL, for example:
        http://localhost:8080/jw/web/userview/app/v/_/list?d-49520-fn_username=admin
