Hi. I'm having a problem, does any of you know how can I populate data from form grid main form into form grid in sub form? Much appreciate if you guys can help. Thanks!
      You could try using JDBC Options Binder in Load Binder, and use SQL to read the DB table containing the form grid record into the subform form.
