    You need to add some code into your configurations. search for THSarabun.ttf in Export Form Email Tool#Advanced
      I got Test.pdf file in the directory, however there are no field in Thai language to show in Test.pdf file.
        String formId = "creditTerm";
        String iid = "01";
        //generate the pdf file in bytes
        byte[] pdf = FormPdfUtil.createPdf(formId, iid, appDef, null, null, null, null, null, null, null, null);
        FileOutputStream out = new FileOutputStream("D:\\Test.pdf");
        out.write(pdf);
        out.close();
