In a datalist can one show/hide columns based on permission? For example show some columns only if the logged in user is admin otherwise hide them when a normal user is logged in.
Similarly, can we show the edit and add button only if the user is admin?
I want to avoid having two datalists to achieve this.
      Thanks for the response Anders.
      I have found the way to add permission in datalists.
      https://dev.joget.org/community/display/DX7/Builder+Advanced+Tools#BuilderAdvancedTools-Permission
      For the Edit button I will use a CRUD for admin users and a List for normal users.
        Hi, you could try to use the Datalist Column#Formatter to perhaps redact or hide certain column values. For the actions, you could try to use Delete Action#VisibilityControls.
