As screenshot, I found my js scriptin calendar menu is invalid which set Week view is default in Joget version is 7.0.19. The new class name of button is fc-timeGridWeek-button, but I modified to "$(".fc-timeGridWeek-button").click();", it also does not work. Is my code error ?
      Hi, if the CSS selector is correct, then it could possibly be the timing of the JavaScript call. You might want to try to set a slight delay before calling the code, for example using the JavaScript setTimeout function.
