How to start a process from the New button on datalist page.
      It is only necessary that in the userview you add a Run Process element (related to the process you want to start, it may be in a hidden section) with a Custom ID (for example runProcess). Then, in the list with which the CRUD was generated, add a Hyperlink element linked to runProcess (additionally enabling the feature: Visible when no record or checkbox)
