thx for your answer. i will try.
I don't think you can concat the hash variable as per your example because you will break the automatic parsing of the hash variable if you separate/break up the hash. If the username in selectbox is already saved to the database, u can retrieve the user's using email using #user.{form.table.username}.email#.
I need to select user from popup select box and get username to find email by using #user.username.email#
I try hardcode #user.cat.email# is worked. i can get cat email.
but try like this
var userName = FormUtil.getValue("commit_empno");
alert("#user."+userName+".email#") ;
I get this #user.cat.email# string , hash variable is not worked.
please help.
