In the hyperlink itself, try to add fieldId=newValue
example: "?applicationType=Renew"
It might helps to override the value.
i use the same form for new process which is application type= new. If set the field to renew then it will automatically renew.
I have one issue with duplicate data plugin.
I try duplicate the data using duplicate data plugin and it works. But I want application type to be automatic as renew when i click renew. But what happen since its duplicate previous id data, it will automatically choose new. U can see below image where when i click renew it will automatically to choose new. Also, i attach my example app.
EXAMPLE APP
APP_duplicate_data-1-20210910185216.jwa
