i working on calculate the different days between two dates which exclude public holiday and weekend.
Here is the code. But its not working. I am not sure which part i missed, the different day not display on the field. It should display 3 days. Also I attach the example app for your reference.
$(document).ready(function(){ { var d1 = $('input[name="d1"]').val(); var d2 = $('input[name="d2"]').val(); $('input[name="diff_days"]').val(workingDaysBetweenDates(d1,d2)); });
let workingDaysBetweenDates = (d0, d1) => { /* Two working days and an sunday (not working day) */ var holidays = ['2021-09-16', '2021-09-17']; var startDate = parseDate(d0); var endDate = parseDate(d1);
// Calculate days between dates var millisecondsPerDay = 86400 * 1000; // Day in milliseconds startDate.setHours(0, 0, 0, 1); // Start just after midnight endDate.setHours(23, 59, 59, 999); // End just before midnight var diff = endDate - startDate; // Milliseconds between datetime objects var days = Math.ceil(diff / millisecondsPerDay);
// Subtract two weekend days for every week in between var weeks = Math.floor(days / 7); days -= weeks * 2;
// Handle special cases var startDay = startDate.getDay(); var endDay = endDate.getDay();
// Remove weekend not previously removed. if (startDay - endDay > 1) { days -= 2; } // Remove start day if span starts on Sunday but ends before Saturday if (startDay == 0 && endDay != 6) { days--; } // Remove end day if span ends on Saturday but starts after Sunday if (endDay == 6 && startDay != 0) { days--; } /* Here is the code */ holidays.forEach(day => { if ((day >= d0) && (day <= d1)) { /* If it is not saturday (6) or sunday (0), substract it */ if ((parseDate(day).getDay() % 6) != 0) { days--; } } }); return days; }
function parseDate(input) { // Transform date from text to date var parts = input.match(/(\d+)/g); // new Date(year, month [, date [, hours[, minutes[, seconds[, ms]]]]]) return new Date(parts[0], parts[1]-1, parts[2]); // months are 0-based }
EXAMPLE APP
APP_calculate_date-1-20210913123836.jwa
// Validate input
if (endDate <= startDate) {
return 0;
days -= weeks * 2;
days -= 2;
days--;
days--;
days--;
return days;
</script>
Thanks.
