Hi experts. How do I display sets of questions based on select box option. What I want to do is the user will first select an option from the select box, let say option1. Then a set of 5 questions is displayed relating to the option1.
I know we can modify the Visibility Control Rules for a section to be display based on the value, however this will display everything in the section. I want to be able to control which question is display based on the option and some question can be available for more than one option for example:
Option1 → Question 1, 2, 3, 4, 5
Option2 → Question 1, 2, 5, 8, 9
Option3 → Question  2, 3, 5
I can easily create multiple sections and use Visibility Control Rules to display certain sections based on value. But if there are easier or better option, please do inform me. I really require your expertise and knowledge regarding this matter. Thank you in advance.
      Hi, you could try some of the articles found in the KB below to see which fits your need best:
      Selectbox Grouping Dependency Based on Parent Form Field
      Dynamic Cascading Drop-Down List
      Show and Hide Form Sections
      You could also use your own custom JavaScript if you really need to by placing the code in a Custom HTML element.
