Hi, did you try using the API Builder? It's a more advanced tool to create and manage custom APIs, and there is built-in support for API keys or tokens in the Manage API Key Menu.
Sorry for the delay Anders!
I want to say the answer is yes ... BUT I have not had a chance to really pick it a part! On first glance, the API element of SSO should work! (see here: SSO)
Thus, I'm accepting the answer ... and will be back with "How Do I NOT stink at the API Builder" questions
Thanks!
Fro
Hello Everyone!
I was looking at the JSON Tool[1][2] to potential push/data into my Joget instance. We have some legacy Excel Macro-based Workbooks people LOVE, some single page web apps, and even HTML Applications that would "work for our forms" (where as the Workflows within Joget are superb – and are forcing the old farts there!)...via the JSON tool.
Now: I know most of the planet is doing HTTPS ... but my Information Security guys would PANIC if they knew the password was being sent around in plaintext. Thus, is there a way to leverage a Token?
For example: I could iframe a login, add Bean Shell/leverage a plugin (maybe in [3]?) – which a user could go to a form to "request a token" ... which would generate a time-duration (e.g., a day, week, month) token ... that could be passed instead of a username/password.
(Unless something in [3] would allow something similar – I need authentication that a user is valid, while NOT sharing login information → to enable JSON Tool Push/pull of data)
I might be over thinking this, but any references/thoughts would help! (Note: if SSO works instead – that might be viable too!)
[1](JSON Tool)
[2](Sample JSON API Integration)
[3](JSON API)
