Replace what you circled in red with form hash variable. Example:-
{"tagging_id" : "#form.request.tagging_id#"}
Using Custom oracle database so its giving null when "#form.tableName.tagging_id#" is used
Hi, to access form data you can use Hash Variable#FormDataHashVariable.
Thanks Anders. But its not working.
how i can use it its not work any other tools
How can i access the form data in the JSON tool, Need to trigger an API call with form data.
![](/community/download/attachments/182321484/JSONTool.JPG?version=1&modificationDate=1637022613000&api=v2)
Tried following
> Custom Payload , POST Parameter as JSON payload
> Creating a workflow variable : #variable.wf_tagui#
> Assigning variable id : {tagui}
