Hello Community,
I want to know if there is a way that i can set formatting of each column of such that when i export the list in Excel, it gives me the exported sheet with formatting already there for each column.
E.g: I want all my columns to be top and left aligned when i export the sheet. Also I want lets say my column "Cost" to be in Number Format/datatype
      Hi, as far as I know there isn't a way to export the formatting by default. You need to perform the formatting in the exported Excel sheet.
      1. Anas Misbah Shami
        Understood.  Thanks
