Joget application is displayed inside an iframe.  When cancel button in approval form is clicked, It change url of parent application and expose joget web-application.
Noticed button is using top.location in generated code.
<button id="cancel" onclick="top.location='/jw/web/userview/usermg/v/_/D89734C6B4AF';return false">Cancel</button>
As a quick fix, Have removed Cancel button using script.
Do we have any solution where button can be kept in form, also prevent application from navigating away from iframe .
      Hi, instead of just removing the button, you could try modifying your script to change the value of the onclick attribute to change the "top" to "window".
