Hi everyone
i have a mysql database 'parts' with table 'stock' which is not the joget JWDB server. i have pulled the data from the stock table, which contains stock_code, description, location and cost to a datalist. so everything is working
i need to create a from that the user can type the stock_code number which will query the 'parts' database for the description, location and cost in the same form in 3 other textboxes. how do i populate these text boxes.
for testing -i have tried using selectboxs to get each field individually. for this purpose how do i make them cascading select boxes?  this will possibly allow me to follow the same logic
is there any method of using a Datalist as selectbox options
any help towards the correct direction is highly appreciated.
regards
DR
      In your select box, choose "options binder" and choose JDBC Options Binder. then you can write your custom SQL to lookup and populate the selection.
      when you are done with it, check out AJAX Subform. use it to refresh the subform (the 3 fields) based on the selection.
