Hi experts,
I am trying to calculate median for a column in a spreadsheet. Is there any way doing this using calculation field? If no, anyone know how to get the value in spreadsheet column so I can work on Java script for median calculation.
Spreadsheet id = spreedSheetASTM
Column id = dumbellThickness
      Hi I've found the method by using Javascript API
        var values = FormUtil.getGridCellValues("spreedSheetASTM.dumbellThickness");
          I also got same question... have u got solution for this?
